| Engine gasket set https://slantsix.org/forum/viewtopic.php?t=37613 |
| Author: | vanman2 [ Thu Oct 22, 2009 6:44 pm ] |
| Post subject: | Engine gasket set |
Hello , i am looking for a good gasket set for my rebuild of my 1987 Dodge B150 225 slant six 3.7 3 spd auto ~~ i was looking at remflex but only saw intake & exhaust ~~ also looking at aussie speed but didn't see a gasket set there either ~~ am i missing something ?? i want to use a real good gasket set ~~ thanks to you all & this forum i learn allot just reading the info you all put out ~~ this is a great forum and some sweet looking motors & rides also probably going to do a trannie rebuild also actually i plan on going thru the whole van top to bottom inside & out we will see |
| Author: | DusterIdiot [ Thu Oct 22, 2009 7:03 pm ] |
| Post subject: | Yep... |
You have to buy a Fel-pro gasket set for the full engine, then just don't use the riser and manifold gaskets...and then buy the Aussie or Remflex gaskets for those specific items... For pre-1980 engines the set is KS2103... and the 1981-1987 crowd that just needs that odd valve cover gasket...is KS2116. -D.Idiot |
| Author: | vanman2 [ Sun Oct 25, 2009 5:14 pm ] |
Thanks for your help |
