It is currently Wed Nov 18, 2026 12:03 pm
PostPosted: Thu Oct 29, 2009 7:41 pm
What is the purpose of the big weight on the tailshaft of some 904 transmissions?
 Post subject: -
PostPosted: Thu Oct 29, 2009 8:28 pm
Just helps dampen vibrations from the driveshaft,just a mickey-mouse way for chrysler to slop a poorly balanced driveshaft on the assembly line without the customer complaining.
 Post subject: Yep...
PostPosted: Thu Oct 29, 2009 8:33 pm
It's an anti vibration/anti-bounce weight, I had one on the 1973 Charger I took to the demo derby... it was kind of weird to see it , considering most other A/B/C/F/M/J body cars I've seen didn't have them...
If it's an A-body...ditch the weight...I had a drive shaft recently balanced...it cost a whole whopping $60... it was worth it.
 Post subject: Re: -
PostPosted: Thu Oct 29, 2009 9:14 pm
Nope, wrong. That weight would not compensate for an out-of-balance driveshaft. It's a harmonic damper to reduce a thrumming noise that has nothing to do with driveshaft balance.
If anyone happens to have a spare such weight, with good rubber bushings, I'm after one to add to my '73.
PostPosted: Thu Oct 29, 2009 10:05 pm
Interesting. I've only ever seen a few. I'll hang on to this one, and keep an eye out for another one for you Dan.
