| Purpose of weight on the tailshaft of the 904? https://slantsix.org/forum/viewtopic.php?t=37708 |
| Author: | Reed [ Thu Oct 29, 2009 7:41 pm ] |
| Post subject: | Purpose of weight on the tailshaft of the 904? |
What is the purpose of the big weight on the tailshaft of some 904 transmissions? |
| Author: | bigslant6fan [ Thu Oct 29, 2009 8:28 pm ] |
| Post subject: | - |
Just helps dampen vibrations from the driveshaft,just a mickey-mouse way for chrysler to slop a poorly balanced driveshaft on the assembly line without the customer complaining. |
| Author: | DusterIdiot [ Thu Oct 29, 2009 8:33 pm ] |
| Post subject: | Yep... |
It's an anti vibration/anti-bounce weight, I had one on the 1973 Charger I took to the demo derby... it was kind of weird to see it , considering most other A/B/C/F/M/J body cars I've seen didn't have them... If it's an A-body...ditch the weight...I had a drive shaft recently balanced...it cost a whole whopping $60... it was worth it. -D.Idiot |
| Author: | SlantSixDan [ Thu Oct 29, 2009 9:14 pm ] |
| Post subject: | Re: - |
Quote: just a mickey-mouse way for chrysler to slop a poorly balanced driveshaft on the assembly line without the customer complaining.
Nope, wrong. That weight would not compensate for an out-of-balance driveshaft. It's a harmonic damper to reduce a thrumming noise that has nothing to do with driveshaft balance.If anyone happens to have a spare such weight, with good rubber bushings, I'm after one to add to my '73. |
| Author: | Reed [ Thu Oct 29, 2009 10:05 pm ] |
Interesting. I've only ever seen a few. I'll hang on to this one, and keep an eye out for another one for you Dan. |
