| Holley carb choke pull off https://slantsix.org/forum/viewtopic.php?t=37709 |
| Author: | Herr Otto [ Thu Oct 29, 2009 8:00 pm ] |
| Post subject: | Holley carb choke pull off |
Does anyone know where I can purchase a choke pull off for a Holley single barrel carb? Model # 1920 and List #3280. Holley no longer carries this choke pull off. Thank you, Herr Otto |
| Author: | SlantSixDan [ Thu Oct 29, 2009 9:33 pm ] |
I have several of these new on the shelf (send me a PM) but you ought to be able to find one locally. I have no trouble pulling one up at rockauto.com, for example. |
| Author: | Herr Otto [ Fri Oct 30, 2009 8:09 am ] |
I have checked, Holley, Advance, Auto zone, Oreilleys, NAPA and Car quest. I will check Rockauto. Thank you, Otto |
| Author: | Herr Otto [ Fri Oct 30, 2009 8:19 am ] |
I just called Rockauto and they do not have it. Do you have a part #? Thanks, Otto |
| Author: | SlantSixDan [ Fri Oct 30, 2009 10:43 am ] |
You called RockAuto? :shrug: C'mon, dude, let your fingers do the walking. www.rockauto.com . Took me three clicks to find the choke pull-off; I'm sure you can do the same. |
| Author: | Herr Otto [ Fri Oct 30, 2009 11:03 am ] |
I called rockauto, and they said their choke pull offs are listed by application and there is none listed for a 1965 Dodge Coronet. Then I asked can't you look it up by Carb # and they said only if I have the choke pull off #. If the guy who works there cant find it I certainly wont. Otto |
| Author: | SlantSixDan [ Fri Oct 30, 2009 11:16 am ] |
It remains a mystery to me how I manage to find parts on rockauto.com that are invisible to others, but here y'go: AIRTEX Part # 1C1171, $11.81 . |
| Author: | Herr Otto [ Fri Oct 30, 2009 4:44 pm ] |
Thank you. The part looks correct, but is says it fits Dodge Coronets 1971-1973. Thanks again, Otto |
