It is currently Thu Nov 26, 2026 1:34 pm
 Post subject: PCV chatter--Why?
PostPosted: Sun Jun 16, 2002 9:52 am
I was working on my &5 Duster the other day and noticed that the PCV valve was chattering. I pulled it out of the VC and plugged the hole with my thumb. It smoothed out the idle and stopped the chatter. I now have it plugged off, but why does it do this? Is this normal(I do not think it would be)? What would cause this? It is a new Fram PCV Valve, the carb is a Holley 2brl on a Super Six manifold. It runs real nice at idle now with it plugged.
Whats up?
scott.solomon@mcchord.af.mil
 Post subject: Re: PCV chatter--Why?
PostPosted: Sun Jun 16, 2002 10:58 am
: I was working on my &5 Duster the other day and
: noticed that the PCV valve was chattering. I
: pulled it out of the VC and plugged the hole
: with my thumb. It smoothed out the idle and
: stopped the chatter. I now have it plugged
: off, but why does it do this? Is this
: normal(I do not think it would be)? What
: would cause this? It is a new Fram PCV
: Valve, the carb is a Holley 2brl on a Super
: Six manifold. It runs real nice at idle now
: with it plugged.
: Whats up?
I would suspect that the vacuum is not constant to the PCV valve. I have seen this when there is a bad intake valve that allows compression to leak past the valve and push the PCV valve closed.
Chuck
webmaster@omnipages.com
PostPosted: Sun Jun 16, 2002 12:18 pm
: I would suspect that the vacuum is not constant
: to the PCV valve. I have seen this when
: there is a bad intake valve that allows
: compression to leak past the valve and push
: the PCV valve closed.
: Chuck
The strange thing is that it does this with the PCV valve out of the valve cover.
PostPosted: Sun Jun 16, 2002 8:58 pm
: The strange thing is that it does this with the
: PCV valve out of the valve cover.
Of course, the pressure that makes it chatter comes from the carb if there is a valve problem. Do a compression check.
Chuck
PostPosted: Sun Jun 16, 2002 10:25 pm
This happened to a buddy of mine. He has a '64 Dodge convert with a 300 HP 360 crate motor. He went to the parts store and looked thru the parts books and found another pcv valve with a different spring, and it cured the problem. If I can remember to ask him, I'll find out the application.
: Of course, the pressure that makes it chatter
: comes from the carb if there is a valve
: problem. Do a compression check.
: Chuck
fglmopar@aol.com
PostPosted: Tue Jun 18, 2002 9:16 pm
If Fram's build quality and quality control on their PCV valves is as poor as it is on their oil filters...then a quick and easy change to a Mopar PCV valve might clear it up.
redbear@vrx.net
PostPosted: Tue Dec 14, 2021 5:24 am
Car Model: 1987 D150
PCV valves are a crap shoot these days. I went through three trying to stop the chatter. Finally found an old metal style off a slant in the junkyard. Put it in now no more chatter.
PostPosted: Tue Dec 14, 2021 7:20 pm
Had the same noise. Cheap PCV valve-try a different brand. Fixed it.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot], Google [Bot] and 6 guests
