| Need wiring diagram for the starter solenoid https://slantsix.org/forum/viewtopic.php?t=37721 |
| Author: | flipfloppop [ Fri Oct 30, 2009 6:31 pm ] |
| Post subject: | Need wiring diagram for the starter solenoid |
Ok i'm about to do some wiring on the slant that i'm putting my 1951 International pickup. So I can get it running before I put it in the truck. What I need is a wiring diagram for the starter solenoid. Pic. would be very helpful to. The motor is a 1978 Plymouth slant super six (225). Any and all help will be appreciated. Thanks for any help . |
| Author: | Fopar [ Fri Oct 30, 2009 10:53 pm ] |
The solenoid Relay S = starter from ign switch G= neutral safety switch Sol= small wire at starter B= main feed to starter and to battery |
| Author: | flipfloppop [ Sat Oct 31, 2009 6:49 am ] |
Thanks alot Fopar : Do you happen to the parts # for the starter solenoid relay. When I got the slant it didn't have the solenoid relay with it. Thanks for the help. |
| Author: | Springer [ Sat Oct 31, 2009 7:42 am ] |
I looked from 1978 parts catalog and it was marked Relay 8-52-328 but I'm not sure if it is the part number because there was a note that parts indicated by name only, order by description. |
| Author: | flipfloppop [ Sat Oct 31, 2009 8:27 am ] |
Thanks Springer: I will try that # and see what I come up with. Thanks for the help. |
| Author: | Springer [ Sat Oct 31, 2009 9:22 am ] |
I think it is this: http://www.rockauto.com/catalog/moreinfo.php?pk=943200 |
| Author: | flipfloppop [ Sat Oct 31, 2009 10:41 am ] |
Thanks Springer for the fast reply. Thanks for the help. |
