| 10" brakes sbp fronts question-- https://slantsix.org/forum/viewtopic.php?t=37732 |
| Author: | VDART [ Sat Oct 31, 2009 12:08 pm ] |
| Post subject: | 10" brakes sbp fronts question-- |
are all 10" brake drums the same -- in the small bolt pattern? i have a set of finned 10" brakes-- they seem to measure the same as the older style drums I have--- but I do not have bearings & a spindle to check them out on--- would the finned brake fit the earlier say 69 brake spindle-- or was there a change ? thanks Lawrence if it helps the finned drum says kh-09191301-7 then 55722 max dia 10.090 |
| Author: | Michael [ Sat Oct 31, 2009 2:57 pm ] |
There were some nice finned 10" drums used for the early set-up through '72 but they are fairly scarce and/or expensive. '73 - '76 drums use a larger spindle. Your #55722 matches the number cast into a set of the later drums I have sitting here in my garage. So they will require the '73 - '76 spindles etc. Cheers - Mike |
| Author: | VDART [ Sat Oct 31, 2009 4:29 pm ] |
thanks-- i figured that -- but wanted tto be sure--- you need an extra set? |
