Chugging at speed
https://slantsix.org/forum/viewtopic.php?t=37734
Author:  86slantram [ Sat Oct 31, 2009 1:16 pm ]
Post subject:  Chugging at speed
If you read my prev post, I have been working on fixing a few carb related problems on my stock 86 non feedback, un-lean burned truck. So far, so good. Until it got colder. Seems like these brisk mornings are causing (exacerbating) a chugging while under load. The chugging happens at around 3000 and continues until 3500 rpms, at which point it just stops. Mind you, 2 weeks ago, no problem.
Also, when the slixer gets all nice and warm, the problem stops entirely.
Thanks for the feedback
Josh
Author:  Aggressive Ted [ Sat Oct 31, 2009 1:17 pm ]
What is your valve lash?
Author:  86slantram [ Sat Oct 31, 2009 1:21 pm ]
Ted:
I have no idea. I have owned the truck for the better part of 1 1/2 years and never looked into/read up on/adjusted the valve lash.
Author:  86slantram [ Sat Oct 31, 2009 1:24 pm ]
Does it have a lash adjustment if it has hydralic lifters?
Author:  Reed [ Sat Oct 31, 2009 1:27 pm ]
If the motor is the stock 86 motor then thee is no valve lash. Sounds like possibly an ignition miss or a problem in the carb. Hard to say not being there to check everything out.
Author:  coconuteater64 [ Sat Oct 31, 2009 1:49 pm ]
Winter blend gas? :shrug:
Author:  Shaker223 [ Sat Oct 31, 2009 2:42 pm ]
Choke not coming off properly?
Author:  86slantram [ Sat Oct 31, 2009 7:52 pm ]
I replaced some of the vacuum lines as they had hardened and became brittle. Motor was still warm, so no chugging yet.
Shaker
I will check the choke again to make sure. Most likely buy the electric choke with my next paycheck.
