| remflex reuse https://slantsix.org/forum/viewtopic.php?t=37767 |
Page 1 of 2 |
| Author: | Joe Colby [ Mon Nov 02, 2009 11:36 am ] |
| Post subject: | remflex reuse |
When I put the intake and exhaust manifolds back on my 62 225 last winter I used Remflex gaskets. I'm now taking the intake off to replace with a super six. The gasket sandwiched between the intake and exhaust came off in pieces. For some reason I was under the impression they were reusable. Now I'm wondering if I should pull the exhaust off and replace the big gasket there as well. Ideas??? Thanks. Joe |
| Author: | SlantSixDan [ Mon Nov 02, 2009 12:12 pm ] |
Attempt to re-use the manifolds-to-head gasket only if you want to do the whole job over again. This junction needs a new gasket each and every time. |
| Author: | Joe Colby [ Mon Nov 02, 2009 5:07 pm ] |
Thanks Dan, that's what I was afraid of. Tomorrow I'll take the whole thing apart and start over. Joe |
| Author: | Aggressive Ted [ Mon Nov 02, 2009 6:35 pm ] |
| Post subject: | RemFlex Gaskets |
I have reused the Remflex 2.25" donut exhaust gasket many times. If the surfaces are real clean it won't stick. On the intake if you have any paint on the head it will stick, so sand or scrape it off. If your racing and do manifold swaps spray some cooking oil like (PAM) on the gasket and it will come off just fine with out sticking. The main thing is to not over torque and let the manifolds move around (expand and contract). I use brass Dorman nuts, silver "Never Seize" and torque to 5 pounds. I use the two castle nuts and big brass spacers per the book on the front and rear. I have had excellent results with no leaks! I worked with the company to develop this process. |
| Author: | SlantSixDan [ Mon Nov 02, 2009 6:55 pm ] |
| Post subject: | Re: RemFlex Gaskets |
Quote: I have reused the Remflex 2.25" donut exhaust gasket many times
Great...groovy...grand......but that's not the gasket he asked about. |
| Author: | Reed [ Mon Nov 02, 2009 7:24 pm ] |
The one Remflex gasket I have even encountered was a manifold to head gasket on one of EricW's motor. It shredded when I pulled the manifolds off the head. It took me about ten minutes of scraping to remove all the leftovers from the head and intakes. I wasn't impessed. I have actually had good luck reusing the normal Felpro manifold gaskets several times. Not the exhaust doughnut, but the head to manifold gasket. I have even had good luck reusing Felpro head gaskets. I know I am a real cheapskate, but if your mating surfaces aren't warped then you should be able to reuse the Felpro gaskets (unless they stick and tear). |
| Author: | SlantSixDan [ Mon Nov 02, 2009 7:25 pm ] |
I've seen cheapskates and I've seen cheapskates, but really, let's be serious. If you don't have the money for a new manifold-to-head gasket, you don't have the money for gasoline to drive the car with. |
| Author: | Reed [ Mon Nov 02, 2009 7:32 pm ] |
| Author: | Joe Colby [ Tue Nov 03, 2009 2:56 am ] |
Reed, I remember those days!! Living pay check to pay check and never getting ahead. I couldn't afford gas (and it was at $.26 a gallon) and had to walk to town, it was up hill both ways. The good old days!!! Anyway, I was disappointed in Remflex. I had used a torque wrench and it was together for less than a year. A learning curve there. Back to Felpro. Thanks. Joe |
| Author: | Joe Colby [ Tue Nov 03, 2009 6:03 am ] |
Since the exhaust is coming off would it do me any good to grind out some of the exhaust outlet to make it closer to 2 1/4" or am I better off leaving it alone?? Thanks. Joe |
| Author: | Aggressive Ted [ Tue Nov 03, 2009 6:43 am ] |
I spent some time on mine and opened it to 2.250". At low velocity it helps a little on initial torque below 2000 rpm not having the lip and turbulence. It flows and breathes a little easier. |
| Author: | 6shotvanner [ Tue Nov 03, 2009 7:01 am ] |
I personaly would go with a known 100% sure, seals it up gasket everytime ie Remflex.I'm sure many folks have great luck with Felpro and the likes but the Aussie and Remflex gaskets were developed to make sure of a 'one time and you're done'gasket install.I don't believe Remflex ever said they were reusable nor do I think Felpro markets their gasket as reusable? I have Clifford intake an headers on my slant and used the Remflex,had to loosen everything up and reposition after install and startup,resealed just fine and that was 10thou miles ago. |
| Author: | Joe Colby [ Tue Nov 03, 2009 8:26 am ] |
Ted, thanks, that's the way I was leaning. It's off, I've got a die grinder and carbide burrs so why not. I found an exhaust gasket that has the 2 1/4" hole in it so I've got a good template. 6shotvanner I've got to say my experience with Remflex was less than perfect. For the money I spent on Remflex I could have gotten a whole bunch of Felpro gaskets. One summer and mine came off in pieces. I'm glad you've had good luck with yours. Joe |
| Author: | 6shotvanner [ Tue Nov 03, 2009 10:14 am ] |
Joe,I guess it boils down to expectations |
| Author: | Joe Colby [ Tue Nov 03, 2009 11:12 am ] |
My point of view is I wouldn't reuse Felpro. They're inexpensive enough so it would have been easier for me to buy a half a dozen of them. I don't mind cleaning up a mating surface before putting a new gasket on. Then I know it's clean. I'm really kind of sorry I brought it all up. Joe |
| Page 1 of 2 | All times are UTC-07:00 |
