It is currently Wed Sep 30, 2026 6:52 am
PostPosted: Wed Nov 11, 2009 4:19 pm
Need to know the correct model Carter carburetor to purchase for my '66 Cuda w/a slant six 225 motor & automatic transmission. Have found two for sale. One is a Carter P 132c and the other is a P 130c. Will either of these work okay? If so, what is the difference between the two. Much thanks.
Shane
PostPosted: Wed Nov 11, 2009 4:56 pm
Neither of those is a carb number - they're casting numbers, and those castings were used on a _lot_ of different Carter BBS carbs. Don't buy a "remanufactured" carb; they're junk -- see here.
If you need a new correct '66 Carter BBS, send me a PM; I have one available.
