| What rearend would be best to put in my truck https://slantsix.org/forum/viewtopic.php?t=37813 |
| Author: | flipfloppop [ Thu Nov 05, 2009 6:43 pm ] |
| Post subject: | What rearend would be best to put in my truck |
Hello, I'm planing to put a "78" plymouth super six in my "51" International pickup and I would like to know anybodys input on what rearend would be best to put in the truck. I only have the motor and transmission no driveshaft or rearend. What do you think will work the best. |
| Author: | coconuteater64 [ Thu Nov 05, 2009 7:28 pm ] |
Not sure, but you might want to snoop around at www.killbillet.com because they do this sort of thing a lot. Seems the S-10 and Ranger/Aerostar rears get used a whole bunch. |
| Author: | Joshie225 [ Thu Nov 05, 2009 8:00 pm ] |
How wide (drum-to-drum) does it need to be to center the tires under the fenders? |
| Author: | flipfloppop [ Fri Nov 06, 2009 5:28 pm ] |
Quote: How wide (drum-to-drum) does it need to be to center the tires under the fenders?
From drum to drum it is right at 60 1/2" but I can go about 1" to 1 1/2" either way. I have no bed for this truck so if I have to go either way with it I can do so.Tahnks for the help. |
| Author: | Joshie225 [ Fri Nov 06, 2009 9:18 pm ] |
I like 8 3/4 rear ends myself for strength and ease of gear changes. The '68-'70 B-body is 60 1/8", '65-'69 C-body is 61.75". If you want to look at other Chrysler rear ends check out the rear axle tech section on Moparts. http://www.moparts.org/Tech/Archive/axle.html |
| Author: | flipfloppop [ Sun Nov 08, 2009 6:11 am ] |
Thanks Joshie225, for all of the help. |
