Thumping coming from the rear in a right hand corner
https://slantsix.org/forum/viewtopic.php?t=37875
Author:  Swiger74 [ Mon Nov 09, 2009 11:20 am ]
Post subject:  Thumping coming from the rear in a right hand corner
I when I take a right hand corner and the car is in gear i get a thumping noise, but when I use the clutch the noise stops. If I let the clutch out the noise starts again. I was wondering if any of you have any idea's what would make it do this. I replaced the shocks and I am thinking it might be the wheel bearing on that side.
Author:  Izzy Michaels [ Mon Nov 09, 2009 1:33 pm ]
i'm not sure but either your brakes are hanging up or if you have a posi- track it's getting locked up or somthing in that area
Author:  bigslant6fan [ Sun Nov 15, 2009 10:10 am ]
Bad trasmission tailshaft mount can cause a thumping noise while coasting.
Author:  Reed [ Sun Nov 15, 2009 10:16 am ]
Possibly wheel bearing. WHen the 7 1/4 axle in my old 84 5th ave went out it started by making a clunking noise going around corners which progressed to a serious banging and shudder. Turned out both the spider gears had teeth sheared off. On a straightaway it would do fine (at least initially) but on the corners it would make noise.
