a 100 trans
https://slantsix.org/forum/viewtopic.php?t=37905
Page 1 of 1
Author:  a-100 sl6 [ Tue Nov 10, 2009 6:43 pm ]
Post subject:  a 100 trans
I am changing an A-100 truck with a 3 speed to a 904 auto. Has
anyone tried this conversion? What type of trans support will
I need? The trans I have has a different tail shaft than the
trans in the truck for support!!
Any help will be appreciated. Thanks
Craig
Author:  Joshie225 [ Tue Nov 10, 2009 6:46 pm ]
A quick question before diving in. Do you know how to weld?
Author:  a-100 sl6 [ Tue Nov 10, 2009 7:03 pm ]
Hi,
Thanks for the response. Yes I have access
to a welder.
Whats next??
Thanks Craig
Author:  Joshie225 [ Tue Nov 10, 2009 7:17 pm ]
The A904 only has a mounting pad on the bottom of the tailshaft. You'll need to make a big collar that surrounds the tailshaft to put a mount in the same position as the original trans. Or you could fab a new transmission crossmember.
How do you plan on shifting the 904? Aftermarket cable shifter is probably easiest. Unless the 3-speed is the same length as the 904 I'm sure you know you'll be having a new drive shaft made.
BTW, what year is the A100?
Author:  a-100 sl6 [ Tue Nov 10, 2009 7:31 pm ]
I have measured the two trans, and they are of
different lengths. I was just wondering if someone
has made trans supports for these conversions. Yes
I will have to make a new drive shaft.The A 100 is a
1968 with a 225 and has fairly nice body. I will be
doing a complete re-do. Hope to be completed in a
year or so.
Thanks Craig
Author:  6shotvanner [ Tue Nov 10, 2009 9:16 pm ]
Craig is the A-100 a van or pickup?
Author:  james longhurst [ Wed Nov 11, 2009 9:11 am ]
Craig,
Join the Yahoo A-100 group and you'll find some pics of a conversion using a B-van crossmember tied in to the A-van subframe. Pretty slick install and looked fairly easy.
-James
Author:  64'4$peed [ Wed Nov 18, 2009 2:41 pm ]
Pm me if you need pics of the stock 727 setup. I dont have any at the moment but can get take em if you need em
Author:  jason white [ Sat Nov 21, 2009 5:27 pm ]
pics of the truck ?
Author:  bigviking0001 [ Tue Apr 06, 2010 11:52 am ]
Craig,
I bought an A100 PU with a /6 and 904. This was a swap done about ten years ago by someone who I don't know. It was pretty slick. The automatic uses the original 3 on the tree shifter for the auto. I'll get some pic as soon as i can. :shock:
