It is currently Tue Nov 17, 2026 5:48 pm
 Post subject: spool interchange
PostPosted: Tue Nov 10, 2009 5:49 pm
SL6 Racer
I have a 741 case 83/4 with a spool, will the spool interchange to a 742 case with the appropriate 742 gears?
PostPosted: Tue Nov 10, 2009 5:51 pm
Spool should be the same, but I'm pretty sure it takes different carrier bearings, or at least one is different. :shock:
Users browsing this forum: Amazon [Bot] and 1 guest
