engine date I.D. where?
https://slantsix.org/forum/viewtopic.php?t=37940
Author:  titan [ Fri Nov 13, 2009 9:21 am ]
Post subject:  engine date I.D. where?
hello, can someone tell me where the date of engine stamping is located on the block on the /6 please ? Thank you, Brian.
Author:  hantayo13 [ Fri Nov 13, 2009 10:01 am ]
head deck under #1 plug behind alt
Author:  titan [ Fri Nov 13, 2009 12:27 pm ]
are you saying on the cyl. head itself? I need to know the date of the block, I have replaced the head with a different onein the past.
Author:  SlantSixDan [ Fri Nov 13, 2009 12:34 pm ]
No, it's on the block itself, on the top surface of the block deck, usually directly below the frontmost spark plug. If you have a late-production block it may be below the rearmost spark plug. If you have a 1960 block, it may be on the rear or top of the water pump scroll area.
Author:  Doc [ Fri Nov 13, 2009 2:23 pm ]
It should be on this boss:
