| wheel hole pattern chart https://slantsix.org/forum/viewtopic.php?t=37944 |
| Author: | DadTruck [ Fri Nov 13, 2009 6:15 pm ] |
| Post subject: | wheel hole pattern chart |
I thought that I saw a posting with a chart in this forum that showed one how to measure the hole pattern size on wheels with 4, 5, 6 bolt holes, on some sizes you measure across holes from the hole center, others are measured from the inner edge,, anyone know where that is,, I usually have some luck with the search function, not this time. thanks |
| Author: | Red [ Fri Nov 13, 2009 9:21 pm ] |
I bought a cheap, plastic template at a swap meet . Makes checking bolt patterns quick and easy, Looks kinda like this one: https://www.made4uproducts.com/cart/pro ... d=80-21392 |
| Author: | '74 Sport [ Fri Nov 13, 2009 9:24 pm ] |
On five-bolt patterns hook your tape measure on the outside of one stud and measure to the center of the one diagonally opposite. |
