It is currently Sun Nov 15, 2026 11:00 pm
 Post subject: Old 904 Vs newer 904's
PostPosted: Wed Nov 25, 2009 3:20 pm
Apologies if this subject is elsewhere...
My '62 Savoy has the original 904 in it, a newer 225 from a '77 Aspen was partially installed. Now, There was mention of an adapter ring required to properly mate the older 904 TC with the newer 225 crank. Would a torque converter from a newer 904 also work? I found one in my "collection of parts" (as my wife euphemistically refers to it :lol: )
I'm going to have to pull the engine out anyway, so I can go either way on this. Clean up the spare TC ($$$ as it sat outside and most likely has dirt in it)or send $25 to Doc for the ring.
'62 Plymouth Savoy Wagon
'64 Chrysler 300
'47 Farmall H
Merlins are cool
Radials rule
Jets drool
PostPosted: Wed Nov 25, 2009 3:48 pm
6 Pack Dart
The older convertor has a smaller front pump input shaft. Don't think the newer convertor will even drive the front pump on the older transmission, just get the adapter ring and end the problem. :wink:
PostPosted: Wed Nov 25, 2009 3:54 pm
Fopar's right.
PostPosted: Wed Nov 25, 2009 4:46 pm
Roger that.
Thanks!
'64 Chrysler 300
'47 Farmall H
Merlins are cool
Radials rule
Jets drool
PostPosted: Fri Nov 27, 2009 11:03 am
Dan and Richard,
How would that work in reverse...ie, 66 225 and newer 904.
PostPosted: Fri Nov 27, 2009 1:02 pm
Dan and Richard,
That doesn't fit. The larger torque converter hub of the late transmission doesn't fit into the small crank pocket.
PostPosted: Fri Nov 27, 2009 11:37 pm
Car Model: 1964 Valiant V200
Dan and Richard,
Find a good transmission shop they can cut two converters apart and build you a custom one. I had it done once and it worked very well.
PostPosted: Sun Nov 29, 2009 2:18 pm
Good to know. Glad I asked first. Since I am going to have a custom converter made anyway, I'll make sure to let the shop know what my needs are. Thanks again fellas. I have the old converter so it shouldn't be an issue.
