It is currently Sun Jun 14, 2026 9:56 pm
 Post subject: carburator
PostPosted: Thu Feb 04, 2010 7:52 pm
Building a sheet metal intake and tube headers for my slant six. i am wanting to convert it from the single barrel carb to a two barrel. What carb came on the original super six motors? is there a preferable two barrel carb other than the super six's?
thanks
PostPosted: Thu Feb 04, 2010 10:05 pm
Check out page 44 in manual #1 (the first link) on this page:
http://slantsix.org/forum/viewtopic.php?t=38601
Some people have used a BBD from a 318, but the true Super Six carb is supposed to work better on a slant. You should be able to find one on e-bay. Good luck.
Roger
PostPosted: Fri Feb 05, 2010 7:39 am
The super six had a Carter BBD or a Holley 2280. Another good choice is the Holley 5200.
Hope this helps,
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Feb 05, 2010 12:40 pm
thanks to you both, this helps a lot.
Hello, operator.
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
