Stupid Cylinder Head Question
https://slantsix.org/forum/viewtopic.php?t=38080
Author:  Dennis Weaver [ Tue Nov 24, 2009 5:02 pm ]
Post subject:  Stupid Cylinder Head Question
I have always been under the assumption that all /6 cyl heads are interchangable with small differences in the casting, plug style, etc.
I am also familiar with the hydraulic cammed /6's that use "top down" tappet oil supply.
I have a friend who is being warned against putting a head from a hydro-cam motor on his '75 slant six. The source of this warning is normally a very trusted source (been a Chrysler mechanic and general gear-head and knowledge dome since way-way back ;) ). As I mentioned, I thought they were all interchangeable, but I have never personally attempted a swap from an '80s model /6.
I know about the funky rear rocker bolt and the different valve cover, but shouldn't one be able to put an '80s head on a '75 motor using the mechanical pushrods/rocker gear with no problems?
D/W
Author:  Doc [ Tue Nov 24, 2009 5:12 pm ]
The valve cover & gasket will also be different.
As long as you allow for the differences noted, the heads will inter-change.
Dd
Author:  Dennis Weaver [ Tue Nov 24, 2009 5:24 pm ]
Thanks,
I'll pass it along.
D/W
