It is currently Sun Nov 15, 2026 6:16 pm
 Post subject: 8.25 Sure Grip
PostPosted: Wed Dec 02, 2009 12:58 pm
Wanting to put a 8.25 sure grip in the wagon but,I was told there are different sizes depending on what gears you use ?
I have 83/4 and dana in my other cars so the 8.25 I'm not familiar with.
So is this a true statement on the 8.25 of different sizes ?
Thanks,
Bill
1966 Plymouth /6 Valiant Wagon
1969 Plymouth Road Runner
 Post subject: Quick break down...
PostPosted: Wed Dec 02, 2009 6:11 pm
There are a few guidelines you need to follow:
1) axle shaft spline changes at 1997...so late 60's to 1996 will ahve the 27 spline housing/sure grip a stock A-body sure grip/housing would have.
2) housing change also between 2.26 to 2.45, and 2.76 to 4.56... you can't put the 2.76 up on the housing meant for a 2.45 or lower, and vice-versa
3) Dodge trucks commonly have what the service manual called the 8 3/8" rear under them...it's just a heavy duty version of the 8.25" so you can use the guts from one (pre-97) in your 8.25"
4) There also seems to be a split about 1972 with regards to bearings for some reason (all my rears are 1974+, so I never have worried...mostly this problem might occur if the axle or parts were used from a B/C body around that time period).
That should get you started.
PostPosted: Sat Dec 05, 2009 9:56 am
Thanks,
That what info I was looking for and that's similiar to what I was told from a tranny/rear end guy but,not a Mopar person.
That will get me what I need for the car.
Thanks,
Bill
 Post subject: Excellent.
PostPosted: Sat Dec 05, 2009 2:16 pm
You are very welcome.
