It is currently Mon May 18, 2026 6:45 am
PostPosted: Sun Aug 29, 2010 8:43 am
Hi.
I read that automatically adjustable brakes were introduced in the 1962 model year but the source didn't say when during the model year it was done. I have manually adjustable brakes and would like to swap over to automatic adjusters.
I have 9" X 2 1/2" drums up front and 9" X 2" drums in back. Advance Auto has the same brake shoe part number for both '62 and '63 Valiants, so I assume the back would be easy. Do the backs just require a new hardware kit or does the backing plate need to be changed or modified?
I know nothing about the fronts regarding swap-ability.
I know I could simply buy the parts to see if it'll work but all the parts involved are all "in the warehouse" and thus need to be ordered with the usual 1-2 day wait.
I'd rather know before buying anything because I don't want to have them order stuff in for me just for a look-see. It's a hassle for them and takes two visits to the store for me. I also have employees and they can lose their focus if I'm not around. It has cost me a lot of money to leave the job for simple errands as I've had to undo stuff that was done while I was absent; the necessary extra labor hours and new materials can add up.
Does anyone here know if I can simply swap things out? If not, does anyone know what must be done? I am tired of keeping them adjusted. I just want to back up a bit, you know?
Thank you for any help and time.
PS I'm glad to be a member of the forum as Mopar-friendly environments make me feel right at home.
Aut nex vel an recolitus vita.
PostPosted: Sun Aug 29, 2010 1:10 pm
Yes, you can simply swap the parts provided they come from the same size brake system... 9" in the case of your '62. There was a substantial improment in self adjusters sometime in the late 60s or early 70's so if you're going to do the upgrade you should get the latest version. Do a search as quite a bit has been posted about this subject.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
