It is currently Sat May 30, 2026 1:08 pm
 Post subject: Cam Plug Sizes
PostPosted: Fri Dec 18, 2009 9:25 pm
I just got the Block Back from the shop for ruster, and i have just got done installing the rear cam bearing and was going to install the ream cam plug too - I have a whole box of 2 9/64's plugs ready to go and Bam! it 's too small.
The other blocks I used - 69 - up use the 2 9/64's This is a 64 truck block so it looks like a 2 1/4" cam plug.
Is this correct before I go and order one??
Thanks a bunch.
PostPosted: Fri Dec 18, 2009 9:31 pm
You could always wrap duct tape around the plug to make it bigger..................
:mrgreen:
