The case of the dead Starter
https://slantsix.org/forum/viewtopic.php?t=38255
Author:  68barracuda [ Wed Dec 09, 2009 1:10 pm ]
Post subject:  The case of the dead Starter
OK not my slant but the 318 and since they use the same starter and electrics.......
Turn key - no starter
short out bat and relay feed on starter no go......
Take the one from the Chargers stripped parts bin - It worked before...
short out bat and relay feed on starter - starter runs...
OK test Starter relay output - zilch
Replace
Turn key.. no starter |^%$!!!!!!!!
Test THIS relay... (*&^%$#@!!!!!! dead
Bought new ones plus 2 spare now all is well
And the original starter... well it is in for a rebuild
31 years is not bad for such a relay
The fact that both failed at once is bad that I did not cotton on to this early on and do my normal test is even worse
That they both kept working ........
Author:  slantsixlancer [ Wed Dec 09, 2009 6:29 pm ]
sometimes they give you love and some times they demand it....
I dont care what any one says...%$%$#$# usually works sooner or later :wink:
