| Over the center spring with a diaphragm pressure plate https://slantsix.org/forum/viewtopic.php?t=38290 |
| Author: | fzmax [ Sat Dec 12, 2009 12:22 pm ] |
| Post subject: | Over the center spring with a diaphragm pressure plate |
The 4-speed swap is almost complete. Once my driveshaft arrives I can drive the thing. The clutch is a stage 2 Spec which has a diaphragm pressure plate. The first time I stepped on the pedal it went to the floor and stayed there. I thought that the over the center spring was optional when using a diaphragm pressure plate. The pedal is very light so that shouldn't be a problem, but they are so hard to get back on I'd hate to remove it and have to reinstall it later. Any input or tricks to getting it back on should I have the need? |
| Author: | Greg Ondayko [ Sat Dec 12, 2009 1:07 pm ] |
You wont need it on for a diaphragham plate. YOu will only need it if you go back to the 3 finger plate - Just keep it in the attic and a tire iron is your friend for the uninstall / reinstall. Greg |
| Author: | fzmax [ Sat Dec 12, 2009 7:06 pm ] |
Thanks. The pedal pressure is so light now I can't imagine I'll need it. Can't wait to drive it! |
| Author: | bob fisher [ Sun Dec 13, 2009 11:11 am ] |
| Post subject: | diaphragm pressure plate |
how well do you expect the diaphragm pressure plate to stand up under normal usage. never used one on a slant six, always the borg and beck 3 finger type. been thinking of it the next time i do a clutch job. they are noticeably softer to step on than the original equipment. have heard rumors that they dont last as long. thanks bob f |
| Author: | fzmax [ Sun Dec 13, 2009 12:21 pm ] |
It's a stage 2 Spec clutch, it's supposed to be good for 550 foot pounds of torque. Since that's about 10 times what the 170 puts out now I don't think it'll be much of an issue. |
| Author: | Greg Ondayko [ Sun Dec 13, 2009 6:54 pm ] |
have had Mine in the dart for 5+ years now - It's not a daily driver but 100's of dragstrip runs and also A couple 1000 mile highway trips to michigan, and Carlisle and Baltimore - Fine for me. Greg |
