Determaning Compression Ratio
https://slantsix.org/forum/viewtopic.php?t=38300
Author:  emptypockett [ Sun Dec 13, 2009 10:51 am ]
Post subject:  Determaning Compression Ratio
I was wondering if there is a way to tell the compression ratio on a assembled engine :?:
Author:  SlantSixDan [ Sun Dec 13, 2009 10:54 am ]
Only if you measured all the relevant parameters before assembling it: Bore, stroke, piston deck height, combustion chamber volume, cylinder head gasket bore and compressed thickness.
Author:  Doc [ Mon Dec 14, 2009 9:29 am ]
You need to dis-assemble and measure everything in order to get an accurate static compression ratio number.
For an assembled engine, test the dynamic compression ratio (cranking pressure in psi) and "leak-down" rate... that can tell you a lot about your combination.
