It is currently Sun Jun 07, 2026 11:13 pm
PostPosted: Sun Dec 13, 2009 10:51 am
I was wondering if there is a way to tell the compression ratio on a assembled engine :?:
SOOOOO much money spent and I keep gettin' told that I could have had a V-8
PostPosted: Sun Dec 13, 2009 10:54 am
Only if you measured all the relevant parameters before assembling it: Bore, stroke, piston deck height, combustion chamber volume, cylinder head gasket bore and compressed thickness.
PostPosted: Mon Dec 14, 2009 9:29 am
You need to dis-assemble and measure everything in order to get an accurate static compression ratio number.
For an assembled engine, test the dynamic compression ratio (cranking pressure in psi) and "leak-down" rate... that can tell you a lot about your combination.
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
