| Help me to identify this head!!! https://slantsix.org/forum/viewtopic.php?t=38317 |
| Author: | Polara1974 [ Tue Dec 15, 2009 5:42 am ] |
Now that I'm checking the pictures better I think the number is 4104362 ... |
| Author: | wvenable [ Tue Dec 15, 2009 6:12 am ] |
The casting number would indicate 1979 - 1980. Have a good one! |
| Author: | 63Valiant [ Tue Dec 15, 2009 6:31 am ] |
That port in the rear is for the smog, (air), pump. |
| Author: | SlantSixDan [ Tue Dec 15, 2009 7:42 am ] |
The hole in the rear is for secondary air injection; an emission control technique that involves injecting air into the exhaust ports so that unburned fuel in the exhaust will finish burning. There's a blockoff plate available for this hole (at least up here), part number 3751 249 with gasket 4275 834. |
| Author: | Polara1974 [ Tue Dec 15, 2009 9:28 am ] |
Quote: The hole in the rear is for secondary air injection; an emission control technique that involves injecting air into the exhaust ports so that unburned fuel in the exhaust will finish burning. There's a blockoff plate available for this hole (at least up here), part number 3751 249 with gasket 4275 834.
Isn't the plug in the head already? I remove the bolt took off the "teardrop" shape metal plug and there was the hole. Is this spot an easy leak for the exhaust?So, in terms of performance this is an overall better head than the early ones with old chamber and spark plug tubes, right? Thanks all for your answers!! |
| Author: | Doc [ Tue Dec 15, 2009 9:52 am ] |
The "peanut plug" heads are about 8 lbs heaver then the SP tube type heads. The exhaust ports have more 'contours' in the bowl area under the valve so they take a little more porting work to get cleaned-up. Over-all... the later heads flow about the same as the earlier versions. DD |
| Author: | SlantSixDan [ Tue Dec 15, 2009 9:54 am ] |
Quote: Isn't the plug in the head already? I remove the bolt took off the "teardrop" shape metal plug
Yep! That teardrop-shaped plug is the plug I mentioned.Quote: Is this spot an easy leak for the exhaust?
Not if the plug is sealed up OK with a good gasket.
| Author: | Polara1974 [ Tue Dec 15, 2009 10:43 am ] |
I'll have to check if my Fel-Pro engine gasket set has the one for this plug. I thought that it might be a place for leaks because it only has one bolt on one side, maybe with two bolts it will seal for sure. One again, thanks!!! |
| Author: | Doc [ Tue Dec 15, 2009 11:19 am ] |
If you are concern about leaks, tap-out the hole with a 3/8-NPT tap and install a pipe plug. DD |
| Author: | Polara1974 [ Tue Dec 15, 2009 12:45 pm ] |
Good idea! Once again, is this the head to use for a performance modified Slant better than an early combustion chamber + spark plug tubes ones? I think so, what do you think? The combustion chamber seems better on the spark plug side on this one. |
| Author: | Doc [ Tue Dec 15, 2009 1:37 pm ] |
All SL6 heads fron 1968 forward have the revised combustion chamber and yes, that design is better then the 60-67 design. DD http://www.slantsix.org/articles/combus ... hamber.htm |
