| Not idle on holley 1920 https://slantsix.org/forum/viewtopic.php?t=38410 |
| Author: | SL6 CHILE [ Fri Dec 25, 2009 2:37 pm ] |
| Post subject: | Not idle on holley 1920 |
Hi guys, merry christmas for alls! Not idle on holley 1920, but if i close the idle air bleed the idle comeback. This problem is not permanent. |
| Author: | SlantSixDan [ Fri Dec 25, 2009 2:51 pm ] |
Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download. |
| Author: | SL6 CHILE [ Fri Dec 25, 2009 3:06 pm ] |
Thanks Dan. The carburetor was a rebuild, but the idle system not working. This carburetor it´s very easy to rebuild, i dont understand the problem. The problem is not permanent and the main metering system works very well.. |
| Author: | SL6 CHILE [ Fri Dec 25, 2009 4:32 pm ] |
Any idea, please |
| Author: | SlantSixDan [ Fri Dec 25, 2009 5:01 pm ] |
Transient problems like this suggest there's dirt or corrosion in some of the very small idle passages in your carb. You may want to try using a spray can of carburetor cleaner to backflush the two idle air bleeds (one small and one tiny) that face the sky; you can see them on the front wall of the carb throat once you remove the air cleaner. |
| Author: | SL6 CHILE [ Sat Dec 26, 2009 6:37 am ] |
Thanks Dan. The idle system has a idle well (i saw in the pdf and in the carburetor) and in my carburetor he moves to top and bottom. is normal ?? Sorry for my inglish |
| Author: | SlantSixDan [ Sat Dec 26, 2009 8:31 am ] |
I'm not sure what part you mean by "idle well". Can you show us in one of the pictures? |
| Author: | SL6 CHILE [ Sat Dec 26, 2009 8:38 am ] |
Dan the part is a brass tube on the galosine pass to the main jet to idle system. |
| Author: | Aggressive Ted [ Sat Dec 26, 2009 9:38 am ] |
SL6 CHILE, On page 13 of the 1920 manual, figure 6 shows a picture of the idle well. You can pull the screws holding the economizer body (see figure 8a) in place and clean out the passage way with a piece of 10 to 12 pound nylon fishing line and blow it out with carb cleaner. If that doesn't work and you hit a some blockage use a guitar string. That should clear up your problem. |
| Author: | SlantSixDan [ Sat Dec 26, 2009 10:29 am ] |
That brass tube should not move. It should be solidly fixed in place. |
| Author: | SL6 CHILE [ Sat Dec 26, 2009 10:53 am ] |
Hi guys, good news! I clean the economizer body and the slant works perfect. Thanks for your help. Greetings from Chile |
