Tachometer question
https://slantsix.org/forum/viewtopic.php?t=38417
Author:  redfourjohnd [ Sat Dec 26, 2009 10:58 am ]
Post subject:  Tachometer question
Hi,
I bought a tach for my Charger. It says it's calibrated for an eight cylinder, and modifying it will void the warranty.
Will it work with the slant?
Thanks!
John D
Author:  Fopar [ Sat Dec 26, 2009 12:14 pm ]
Depends on mfg of tach, some are set up for 8 cyl but have instructions on how to set up for 4 or 6 cyl.
Author:  Joshie225 [ Sat Dec 26, 2009 3:22 pm ]
If there aren't switches or a wire loop to cut to change the number of cylinders the tachometer will read properly then you need a different tach.
Author:  redfourjohnd [ Sat Dec 26, 2009 8:31 pm ]
Thanks for the info guys.
I got my tach from chargerspecialties.com. I'll call them on Monday to figure out how I can get it to work. They manufacture them so I hope they can tell me how to modify it, or make me one that will work.
I'm just glad that I realized it might not work before I put the cluster back together! Putting it back in the car and having to pull it again wouldn't have been fun.
Thanks again,
John D
Author:  redfourjohnd [ Mon Dec 28, 2009 5:41 pm ]
Hi Guys,
Talked to the manufacturer, and he said there is an adjustment on there, but I would need another tach to confirm the new setting.
I mailed it out to him to re-calibrate it. Seemed easier.
Thanks again,
John D
