| Oil Pump https://slantsix.org/forum/viewtopic.php?t=38532 |
Page 1 of 3 |
| Author: | maxracer21 [ Wed Jan 06, 2010 10:21 am ] |
| Post subject: | Oil Pump |
Has anyone experimented or fabricated an external oil pump yet?..........I have experimented and made a mopar pump work but heck..........there has to be a better way. Thanks in advance for any info..........seems like you guys have just about tried everything. Best regards to ya d taylor |
| Author: | sandy in BC [ Wed Jan 06, 2010 10:26 am ] |
Several guys have done this....notably Terry Littlejohn has made one from a Powersteering pump.. |
| Author: | ValiantOne [ Wed Jan 06, 2010 11:05 am ] |
If memory serves me Ron Hamby (sp?) had an external pump on his 66 dart at the Mason Dixon drags last spring. I beleive he is a member, but I dunno his username. C |
| Author: | Kevin Johnson [ Thu Jan 07, 2010 5:40 am ] |
| Post subject: | Re: Oil Pump |
Quote: Has anyone experimented or fabricated an external oil pump yet?..........I have experimented and made a mopar pump work but heck..........there has to be a better way. Thanks in advance for any info..........seems like you guys have just about tried everything. Best regards to ya
That sounds like a good idea.
d taylor |
| Author: | 66aCUDA [ Thu Jan 07, 2010 7:15 am ] |
I have a home mode adaptor that uses hoses(AN Stuff) to a remote electric pump. Frank |
| Author: | Rick Covalt [ Thu Jan 07, 2010 12:15 pm ] |
| Post subject: | Pump? |
Frank what kind of electric pump are you using? Pics? I too have wondered about a poor mans external pump arrangement. I thought of a Power steering pump but had no idea of how much pressure or volume they could put out. Are there any other factory pumps out there that would lend themselves to being mounted so they could be belt driven? I I thought Terry used a stock Mopar pump and drove it off a belt. I also though he had some leakage issues. I may be wrong too. Rick |
| Author: | Greg Ondayko [ Thu Jan 07, 2010 2:21 pm ] |
Yes Ron Hamby's car has a naked Right side on the block - Dist - Gone Fuel Pump =Gone Oil Pump / Filter etc=Gone Camshaft= Thats still there! Just plyin! All non stock stuff on his car for these critical engine functions. Sorry I dont Have a pic. Greg |
| Author: | adiffrentcity [ Thu Jan 07, 2010 5:35 pm ] |
Isn't there a pic of his engine bay in the SSRN #53? I'll go look. Running a motor plate certainly opens up your options on accessory location! |
| Author: | terrylittlejohn [ Thu Jan 07, 2010 5:56 pm ] |
i used a stock /6 pump with a tapped block-off plate, and used a external line to the sump and 2 3/8 lines back to the block, the pulleys were serpintine power steering, they were bushinged to fit the pump and drill to fit the crank, the pump shaft was drilled and tap to hold the pulley along with a keyway. the hardest thing was catching the oil that weeped past the shaft which lube it. i cut an inch of the oil pump snout and used a copper plumbing adaptor with a barbed nipple siolder in it and expoxyed to the pump, a line to the base returned the oil, a small oil seal was pressed into the copper adaptor with some expoxy and sealed against the shaft. it worked put took a lot to get the bugs out . the altenator had to be moved because the put has to spin CC wise. |
| Author: | terrylittlejohn [ Thu Jan 07, 2010 6:08 pm ] |
some pits on virtual drag under my car ,also some in ssn letter that sermour had asked for, can`t seem to link them here, i don`t know what i am at with computers?? |
| Author: | maxracer21 [ Thu Jan 07, 2010 6:55 pm ] |
| Post subject: | oil pump |
things are coming together now..........thanks Terry I'll prob have more questions if that's ok w/you best regards |
| Author: | maxracer21 [ Thu Jan 07, 2010 7:07 pm ] |
| Post subject: | powersteering oil pump? |
This was interesting did it work????????? |
| Author: | 66aCUDA [ Fri Jan 08, 2010 6:19 am ] |
Mine is an Alum plate with "chambers" in it. Electric pump simular to an electric fuel pump. Set for 60PSI. Frank |
| Author: | GTS225 [ Fri Jan 08, 2010 6:00 pm ] |
Quote: Several guys have done this....notably Terry Littlejohn has made one from a Powersteering pump..
************************************************************Even though Terry's was a slant oil pump, just used externally, I'd like to explore this idea a bit. I do know that many off-road guys with hydraulic winches have mounted an additional power steering pump to supply the winch, or T'd off of thier existing P/S lines. I don't really know if the P/S pumps are capable of giving sustained flow & pressure numbers that might be required for use in the manner suggested. Anybody have access to such info? What might be a good salvage yard donor for a pump? Maybe something out of a GM hydro-boost application? Maybe it would have to be something from a piece of heavy equipment.....say the hyd. pump from an endloader? Roger |
| Author: | Dart270 [ Sat Jan 09, 2010 9:11 am ] |
Several of the racers have external single-stage (wet sump) external pumps. IIRC, Norm Foster, Dale Rose, and the Drakes used these. Charlie owns one but hasn't used it? I bought a used external setup from someone, but have seen no use in putting it on. Lou |
| Page 1 of 3 | All times are UTC-07:00 |
