| Best Gaskets ? https://slantsix.org/forum/viewtopic.php?t=38538 |
| Author: | Blown 70 [ Wed Jan 06, 2010 11:10 pm ] |
| Post subject: | Best Gaskets ? |
Who makes the best gaskets for a slant ? Mainly oil pump,oil pan,valve cover,fuel pump,etc. Who makes the best head gasket ? I have a /6 on a stand,getting ready for a rebuild,and am gathering the parts for it. Thanks alot. |
| Author: | Greg Ondayko [ Thu Jan 07, 2010 2:32 am ] |
The Fel pro Complete engine set works fine in most situations - There are a few options for the Head gasket and intake / Exhaust gaskets, but If it's a stock build fel- pro. Greg |
| Author: | Blown 70 [ Thu Jan 07, 2010 8:29 am ] |
[quote="Greg Ondayko"]The Fel pro Complete engine set works fine in most situations - There are a few options for the Head gasket and intake / Exhaust gaskets, but If it's a stock build fel- pro. Greg[/quote] Thanks Greg, Planning on bumping up compression by shaving .090-.100 off the head. Just trying to find out what everyone is using ? Thanks again. |
| Author: | Greg Ondayko [ Thu Jan 07, 2010 2:17 pm ] |
Fel Pro will be fine for you in this situation. Greg |
| Author: | Blown 70 [ Thu Jan 07, 2010 5:27 pm ] |
Thank you.......! |
| Author: | DusterIdiot [ Thu Jan 07, 2010 7:15 pm ] |
| Post subject: | Engine Kit... |
Shop around a bit, as you can get most of the parts at a reasonable price for the slant from Northern, or PAW, etc... they tend to use Fel-Pro, Melling pumps/parts, etc... -D.Idiot |
| Author: | Blown 70 [ Thu Jan 07, 2010 8:31 pm ] |
Thank you D Probably pick up Fel-Pro FS7918PT4. Full gasket set. Rock Auto has it for $71.00 |
| Author: | DusterIdiot [ Thu Jan 07, 2010 9:56 pm ] |
| Post subject: | But... |
I think you get all the gaskets needed for much less of a price with the KS2103 gasket set (at least I've rebuilt engines with them and had plenty of spare stuff from the set....) -D.Idiot |
| Author: | Blown 70 [ Fri Jan 08, 2010 12:34 am ] |
Interesting.......They look like they have the same amount of gaskets. I wonder if the one has better qualtiy gaskets ? Pretty sure Fel-Pro has 2 lines. |
| Author: | olafla [ Fri Jan 08, 2010 1:29 am ] |
There is also a very useful list of parts, including gaskets, in the articles section of the forum: Slant Six Parts List. Olaf |
