It is currently Sun Nov 15, 2026 5:33 am
PostPosted: Mon Apr 26, 2010 6:48 pm
for this 65 were working on. I'm still playing around with the electrics.
I installed the new voltage regulator and horn relay today. some progress. Someone installed a Mopar Perf. electronic ignition, so there are some more wiring bodges to deal with.
In my "pre-first start" checklist; I checked the voltage at the ballast resistor with the key in the ON position....it has just shy of 10v. The batter voltage is at 12.1 v.
I THOUGHT the ballast resistor would have 12v in the "start' position, then 6 in the run position. Is that correct? But only for points?
I assume the ballast resistor was changed for the MP electronic ignition.....so what should the voltage be? 10 or 6?
PostPosted: Mon Apr 26, 2010 9:25 pm
No. The ballast resistor is bypassed during cranking by a separate wire.
It's a ballast resistor; its output changes depending on load and load profile. Your 10v reading sounds about right.
PostPosted: Tue Apr 27, 2010 12:01 pm
yes...no load measurement. I just stinks working on other peoples mods.
Thanks for the help Dan!!!
