timing chain
https://slantsix.org/forum/viewtopic.php?t=38607
Author:  USAJon [ Tue Jan 12, 2010 5:33 pm ]
Post subject:  timing chain
when to change..
100K?
I had 212K miles and never did change it
whats the book recommend.
Ive talked to some wrenches and they said they have never changed one....
Author:  ceej [ Tue Jan 12, 2010 5:52 pm ]
100k it's due.
You can check on it's health by checking the position of the rotor in the distributor, watch it, and rotate the engine backward by hand. If the engine rotates much at all before the rotor starts to move, it's time.
CJ
Author:  Doc [ Wed Jan 13, 2010 8:48 am ]
The big question is the top cam gear.
The cast iron gear sets will last a long time, the chain may get loose which can retard the cam timing but these do not skip teeth.
Later SL6 engines with the aluminum / nylon cam gear, tend to go 100 to 150K before the teeth fail.
