| How many turbo /6's are there? https://slantsix.org/forum/viewtopic.php?t=3861 |
| Author: | Matt Cramer [ Thu Jul 04, 2002 9:32 pm ] |
| Post subject: | How many turbo /6's are there? |
Just wondering. I've been trying to put the setup Wayne used to use (shown elsewhere on this site) on my Dart, and it's been slow going, mostly because I haven't had that much time when I can work on it. Anyway, I'm just curious as to how many people have built engines like that. Does anyone have a ballpark figure for how often this has been done? |
| Author: | Tom [ Thu Jul 04, 2002 10:39 pm ] |
| Post subject: | Re: How many turbo /6's are there? |
: Just wondering. I've been trying to put the : setup Wayne used to use (shown elsewhere on : this site) on my Dart, and it's been slow : going, mostly because I haven't had that : much time when I can work on it. Anyway, I'm : just curious as to how many people have : built engines like that. Does anyone have a : ballpark figure for how often this has been : done? Seems like quite a few are going this route. I have always been fascinated by turbos and their potential, but never really tried to build a combo with one. This time I am commited, and with all the info and help available on the web, it will become a reality. Tom sschultz@telusplanet.net |
| Author: | Chuck Rivers [ Fri Jul 05, 2002 3:08 am ] |
: Just wondering. I've been trying to put the : setup Wayne used to use (shown elsewhere on : this site) on my Dart, and it's been slow : going, mostly because I haven't had that : much time when I can work on it. Anyway, I'm : just curious as to how many people have : built engines like that. Does anyone have a : ballpark figure for how often this has been : done? I have an older setup in my garage just waiting to go in my 63 Dart Convert. It came out of a 69 van. Chuck webmaster@omnipages.com |
| Author: | andrew [ Sun Jul 07, 2002 9:16 am ] |
I run a turbo on my slant six. You can go to <A HREF="http://home.earthlink.net/~mrdartgt/">http://home.earthlink.net/~mrdartgt/</A> or wangermotorsports.net I do not have pic of the new setup on there but some of the other thing that I did are on there. I make costom turbo kits for alot of other types of cars to. I got a stock engine to go 14.50 @ 95 mph, that was intercooled and at 10 lbs of boost. I have got a new engine built up with turbo cam ,head work, But I needed to get a bigger radiator so I am running 4 lbs until I get a new intercooler. The new engine ran 15.06 @ 90 at 4lbs. The tranny was sliping pretty bad. If you need any help let me know! andrew wagner Quote:
: Seems like quite a few are going this route. I : have always been fascinated by turbos and : their potential, but never really tried to : build a combo with one. This time I am : commited, and with all the info and help : available on the web, it will become a : reality. : Tom |
| Author: | Tom [ Sun Jul 07, 2002 5:46 pm ] |
| Post subject: | Re: How many turbo /6's are there? *PIC* |
: I run a turbo on my slant six. You can go to : <A HREF="http://home.earthlink.net/~mrdartgt/">h ... dartgt/</A> or : wangermotorsports.net I do not have pic of the : new setup on there but some of the other : thing that I did are on there. I make costom : turbo kits for alot of other types of cars : to. I got a stock engine to go 14.50 @ 95 : mph, that was intercooled and at 10 lbs of : boost. I have got a new engine built up with : turbo cam ,head work, But I needed to get a : bigger radiator so I am running 4 lbs until : I get a new intercooler. The new engine ran : 15.06 @ 90 at 4lbs. The tranny was sliping : pretty bad. If you need any help let me : know! : : andrew wagner Andrew, are you still running the turbocoupe turbo? And if so does it have the .48 housing or the .63? I am going to attempt to use two of the .48 housing turbos on my /6. I am also in the process of building a fairly large intercooler for it. I pondered using the buick gn turbo, but it seems to really work better with an aftermarket downpipe. What type of custom work are you doing? Header, manifold etc? ![]() sschultz@telusplanet.net |
| Author: | andrew [ Sun Jul 07, 2002 10:10 pm ] |
Wagnermotorsports.net I spelled it wrong!!! Here is a pic of the header. My turbo has the .48 exhaust, and .63 compessor side. The gn turbo is a good turbo! looks like your intercooler will be nice. andrew wagner Quote:
: : Andrew, are you still running the turbocoupe : turbo? And if so does it have the .48 : housing or the .63? I am going to attempt to : use two of the .48 housing turbos on my /6. : I am also in the process of building a : fairly large intercooler for it. I pondered : using the buick gn turbo, but it seems to : really work better with an aftermarket : downpipe. What type of custom work are you : doing? Header, manifold etc?
| Author: | andrew [ Sun Jul 07, 2002 10:12 pm ] |
| Post subject: | Re: How many turbo /6's are there? *NM* *PIC* |
| Author: | Tom [ Sun Jul 07, 2002 10:22 pm ] |
Nice looking header Andrew. Do you build and sell these? And if so, how much? Tom sschultz@telusplanet.net |
| Author: | andrew [ Mon Jul 08, 2002 6:05 pm ] |
yes I do! I can make any type of header you want. Its about 350 for a steel header and 450 for a stainless header. I am slowly getting things on the web site together. andrew wagner Quote:
: Nice looking header Andrew. Do you build and : sell these? And if so, how much? : Tom |
| Author: | Tom [ Mon Jul 08, 2002 6:57 pm ] |
: yes I do! I can make any type of header you : want. Its about 350 for a steel header and : 450 for a stainless header. I am slowly : getting things on the web site together. : : andrew wagner What size tubing is the header you have pictured? Tom sschultz@telusplanet.net |
