It is currently Sun Nov 15, 2026 3:36 pm
PostPosted: Fri Jan 15, 2010 1:11 pm
Does any company make an adapter which allows you to bolt a Borg Warner T5 5-speed behind a Slant Six?
PostPosted: Fri Jan 15, 2010 1:27 pm
Its more than just an adapter. In fact bolting a 5 speed to a slantsix bell housing is the easy part.
If you want a bolt in kit.....Keisler makes one for about $3500.
I put a 5 speed in my car for less than $500......it was not boltin. It took 2 days.
These swaps have been recorded on here for a decade.....search is your friend. T5 bell housing group buy
PostPosted: Fri Jan 15, 2010 6:56 pm
Hey ceej if you're reading this I nominate the above group buy for inclusion in the faq! :D
72 dart acquired 12/08 /6,holley2b, mopar perf intake, mopar perf header, cam, built motor,904 finally re-installed, 8.75....still needs sorting out.
99 dakota 318 5 speed reg cab picked up 9/09; Trans finally fixed! woohoo!
PostPosted: Fri Jan 15, 2010 7:42 pm
It was done a few years ago. Occasionally one will turn up for sale. :D
