It is currently Mon May 11, 2026 9:21 pm
 Post subject: water pump
PostPosted: Wed Jan 20, 2010 6:30 am
I am building a 1920's styled roadster, powered by a slant six (of course). Motor is a 1964 225. Got it out of some grandma's rear ended dart. It was a lucky find at 28000 original miles.
Would the stock water pump push coolant well enough to put a rear mounted radiator in the car?
thanks.
PostPosted: Wed Jan 20, 2010 8:29 am
Short answer is NO. I have had a lot of recent heartburn with this on my engine test stand. I wanted to remote mount the radiator and have a valve to by pass it and put it on city water. I will have to use a booster pump or do it a different way.
Also launches will tend to keep the water to the rear and no "flow" will happen for a few secounds.
You may want to try a horazontal unit.
Hope this helps,
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Jan 20, 2010 9:00 am
thank you very much. thats helps greatly.
Users browsing this forum: Bing [Bot] and 9 guests
