It is currently Wed May 13, 2026 7:40 pm
Post new topic  Reply to topic  [ 86 posts ]  Go to page 1 2 3 4 5 6 Next
 Post subject: emergency please help!
PostPosted: Tue Jan 05, 2010 5:52 pm
My daily 225 start but cut off after 2-4 seconds I got fuel, & spark. Help! [/quote]
68 225 Dart "life under the hood, is the life for me" -By Me
PostPosted: Tue Jan 05, 2010 5:56 pm
6 Pack Dart
Broken resister ??
PostPosted: Tue Jan 05, 2010 6:32 pm
Ballast resistor .
PostPosted: Tue Jan 05, 2010 6:40 pm
Both r good.
PostPosted: Tue Jan 05, 2010 6:58 pm
fuel related
PostPosted: Tue Jan 05, 2010 7:29 pm
Car Model: '64 Valiant Convertible
Hold the phone up to it, so i can see it...
If you look down the carb, and activate the accelerator pump, does it squirt fuel? Fresh or reasonably fresh, viable fuel. What is the position of the choke flap?
When you pull a plug wire, and create a reasonable gap, and crank the motor, do you have a consistent spark?
Next, I'd use a timing light to rule out a slipped timing chain, and inspect the distributor for a loose bolt.
Then I'd want to look at the spark plugs if not any firing or back firing.
PostPosted: Tue Jan 05, 2010 8:05 pm
The second I acceleration it cuts of faster.ill check allthose good ideas when i get home thanks
PostPosted: Tue Jan 05, 2010 8:19 pm
Ballast resistor .
No. If it runs at all, even for just a few seconds, it's not the ballast resistor.
PostPosted: Tue Jan 05, 2010 8:59 pm
This may sound like stupid advice from waay back, but have you checked that some little rascal haven't shoved a potato up your tailpipe (the car's, that is!)? Another possibility is that your gas tank is under vacuum if the ventilation is clogged, then you should hear a rush of air intake to the tank when you twist off the gas cap just after the engine has died. I'm serious, I have had cars with both those problems myself. Olaf
Aspenized
PostPosted: Tue Jan 05, 2010 9:44 pm
bad ballast resistor will run as long as key in start position
PostPosted: Tue Jan 05, 2010 10:15 pm
"Up ur tail pipe" hilarious!!!!! No I checked. ill check the vapor thing.
PostPosted: Tue Jan 05, 2010 10:22 pm
your accelerator pump might not be in good shape. could maybe be a fuel pump. ive had both happen in different vehicles. heck my dads 85 toyota's fuel pump went out. you could run it just idling no problem. soon as you put a load on it if you didnt let go of the gas it would die. have you re bult your carb lately?
PostPosted: Wed Jan 06, 2010 12:58 am
Yea I checked the vacuum it was good no start. 7:30 - 20min drive to work. 3:00 -20min drive home. 4:00- 10min 40mph drive to store. 4:30 going back home w/in 2-4min small jolt then a few seconds & cutoff at about 30mph. Could it be my Carb? Weak spark? Owner? (A couple lose bolts lol) site tech ? How do you do that quote thing in this site?
PostPosted: Wed Jan 06, 2010 1:11 am
Yea I have pretty good spark. I will check the fuel next thanx. Man! I got to say you guys sure make a Guy feel like part of slt6 family. Thanx. I keep u guys posted. (By the way Never mine the site ? I figured it out)
PostPosted: Wed Jan 06, 2010 1:14 am
What is your vacuum at idle when the engine is running?
Users browsing this forum: Google [Bot] and 13 guests
