It is currently Thu Jun 25, 2026 9:09 am
 Post subject: Wiper motors
PostPosted: Tue Jan 26, 2010 8:13 pm
I sent the following email to New Port Engineering. They make replacement wiper motors for various vehicles, include early Chrysler products. They primarily cater to the Hot Rodder set.
> I have a 1965 Dodge Dart with the single speed wipers. I have already
> soldered the brass contacts within the dash switch to get them to work
> reliably. They work fine for around town, but just can't keep up at
> freeway speeds. I need an upgrade and there is always that nagging
> feeling of "will they work today..."
> Do you plan, or have you thought about creating a package for this
> vehicle? A kit would cover the years from 1963 to 1966 and handle the
> Darts, Valiants and Barracudas. It would be nice if the kit contained a
> set of bronze bushings to replace the OEM ones. But then, after 44 years
> mine don't look that worn.
> Nobody else has an upgrade for these years and/or body styles. About the
> only upgrade is to a OEM variable speed wiper motor with associated
> parts, but then these are just as old as my current setup.
> Thank you for your time
> Kevin L. Esteb
And received this reply:
> Hi Kevin,
> Thanks for your interest in our products. We currently have nothing for
> your application, however we will look into those cars. If you need
> something right away, we can't help you, but we will look into this.
> Keep a look out for us in Rod & Custom, Street Scene, World of Rods
> magazines,(just to name a few of those we advertise in) we will list
> those when we have something for you.
> Once again, thanks very much for contacting us @ New Port Engineering.
> Sincerely yours,
> Linda @ New Port Engineering
If others are interested in a modern 2 speed wiper motor with optional intermittent wipers, please email them. They may decide that there is enough interest and start development on a kit. Most of their kits are bolt-in using the OEM linkage and mounting points. Their web site is at:
http://www.newportwipers.com
I am not affiliated with this company in any way. I just noticed their ad in Street Rodder.
PostPosted: Tue Jan 26, 2010 8:42 pm
Oops, not quite. The interchange is '64-'66 A-body. The '63 motors and their mounting angles and configurations are totally different.
