My trans. "sometimes" leaks?????
https://slantsix.org/forum/viewtopic.php?t=38787
Author:  bigtex [ Wed Jan 27, 2010 11:01 am ]
Post subject:  My trans. "sometimes" leaks?????
In my 64 dart /6 with a 904 if I let it sit for about a week it will not leak a drop of atf, but if I let it sit for 2 weeks randomly it will dump about 1qt. of oil on the ground in about a 1 hour time frame. After it dumps that 1qt it will not leak anymore. Anyone have any ideas, my thoughts are maybe a anti-bleed back check ball in the torqe converter?? Thanks in advance
Author:  SlantSixDan [ Wed Jan 27, 2010 11:14 am ]
Torque converter drains down, raises level of fluid above trans pan rail, leaky trans dipstick tube O-ring and/or kickdown lever shaft seal and/or shift cable O-ring and/or park cable O-ring and/or park lock housing to main housing gasket and/or speedometer cable O-ring allow fluid out onto the ground.
Author:  bigtex [ Wed Jan 27, 2010 12:21 pm ]
It is coming from the kickdown shaft seal. Thank you for your help, now the search is on to find one :D
Author:  SlantSixDan [ Wed Jan 27, 2010 12:35 pm ]
My '62 Lancer has the same leak from the same place. Get with Pat Blais (tflitepatty@verizon.net ) for a seal kit.
Author:  bigtex [ Wed Jan 27, 2010 1:06 pm ]
I will e-mail him. Thanks again for the help.
