It is currently Thu Nov 12, 2026 10:30 pm
 Post subject: Water Temp Senders
PostPosted: Thu Jan 28, 2010 7:53 pm
Looks like there are several type of sender units. How do you tell which is for a gauge and which is for an idiot light?
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Jan 28, 2010 8:26 pm
A gauge sensor has variable resistance depending on temperature.
An idiot light sensor usually a contact switch that's opened or closed.
PostPosted: Thu Jan 28, 2010 8:32 pm
Thanks ED
Didnt know if it was easy to see the difference.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Thu Jan 28, 2010 9:09 pm
Keep in mind there are different resistance ranges for the temp senders, too, and different terminal types.
PostPosted: Thu Jan 28, 2010 10:00 pm
Car Model: Toad Wagon
..... and keep your receipt. I've found the later range on both type replacements lately, no matter what year fit the box listing was. Took'em back three times before I got smart enough to take a meter with me (sometimes I'm a slow learner) and find that that resistance was all they had.
Finally found some correct ones on e-bay.
Dan, do you know when they changed?
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Fri Jan 29, 2010 8:46 am
All Good info. I just have a box of the sensors that I have pulled off of heads that I accumalated over the years. I dont need the idiot light type so just wondered if you could see the difference. It wont be any problem to set up a pan of hot water and a meter to test them.
Thanks,
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Jan 29, 2010 10:42 am
I know there was a change from '63 to '64, but I'm not sure what changes there might've been after that; I'll have to dig.
