| V8 to slant six motor mounts https://slantsix.org/forum/viewtopic.php?t=38810 |
| Author: | Christopher [ Thu Jan 28, 2010 11:25 pm ] |
| Post subject: | V8 to slant six motor mounts |
New guy here,,,any info on volare clip[under 52 dodge wagon] withv8 spindle mounts[had a 440 in it]to a slant six motor mount kits????Christopher.... .. |
| Author: | Joshie225 [ Fri Jan 29, 2010 8:32 am ] |
Nothing pre-fabricated exists, sorry. If you want something bolt-in you'll have to get a /6 K-member. |
| Author: | radarsonwheels [ Fri Jan 29, 2010 11:31 am ] |
| Post subject: | To go LA to RG you need to extent drivers side up |
The drivers side forked mount that captures the spool needs to be one inch taller for a slant. That should get you close. |
| Author: | Wesola78 [ Fri Jan 29, 2010 4:20 pm ] |
Yeah, I think the driver's side is just a little taller, the passenger side should be the same. As was stated, a kit doesn't exist for this swap. So, trial fit, cut and weld, etc. Sounds like a cool project ride ya got! |
| Author: | Christopher [ Fri Jan 29, 2010 8:44 pm ] |
thanks for the input/ideas. looks like I will need to do some fabrication work,,thats what makes it fun right?? Christopher.... .. |
