| Help https://slantsix.org/forum/viewtopic.php?t=38813 |
| Author: | lonewolfinjax [ Fri Jan 29, 2010 12:10 pm ] |
| Post subject: | Help |
I REALLY NEED SOME HELP HERE,IM TRYING TO PUT MY SIX ON THE K-FRAME OUT OF THE CAR AND IT WILL NOT MOUNT LIKE IT SHOULD.I DID HAVE THE K-FRAME POWDER COATED AND IS IT POSSIBLE I GOT THE WRONG ONE BACK ?? IT DOES LOOK RIGHT.COULD IT BE LIKE A 318 K-FRAME ??? I HAVE THE CORRECT MOUNTS BUT THE MOTOR SITS TO HIGH AND DOSNT LEAN LIKE IT SHOULD.AM I JUST MISSING SOMETHING ?? ANYONE HAVE A GOOD PICK OF WHAT A K-FRAME FOR A 73 DUSTER LOOKS LIKE,BOTH MOUNTING POINTS ??? ITS LIKE THE MOUNT POINT ON THE PASSENGER SIDE IS TO HIGH AND IT WONT LET THE MOTOR LEAN.HELP. THANKS,CHUCK |
| Author: | Doc [ Fri Jan 29, 2010 12:20 pm ] |
It sounds like you have the passenger side engine mount bolted-on up-side-down. The rubber cushion or spool bushing sits right under the fuel pump. DD
| Author: | lonewolfinjax [ Mon Feb 01, 2010 6:40 am ] |
HI DOC,THANKS AND I JUST CHECKED IT, INSTALLED THE OTHER WAY IT WILL BE SITTING REALLY WAY UP AND DOES THE OIL PUMP SIT REALLY CLOSE TO THE K-MEMBER ?? IT LOOKS LIKE THE SPOOL WILL BE VERY CLOSE TO THE FUEL PUMP AND VACUME ADVANCE.ALSO LOOKS LIKE IF I TRY THAT IT WILL PUT THE OIL PUMP ALMOST RIGHT ON THE K-FRAME. IM REALLY LOST HERE AS IM SURE YOU CAN TELL. DO YOU KNOW ANYONE WITH SOME PICS OR ANYTHING ELSE YOU CAN TELL |
| Author: | emsvitil [ Mon Feb 01, 2010 4:06 pm ] |
BTW, ALL CAPS IS CONSIDERED TO BE SHOUTING....... So, please don't use all caps. thanks |
| Author: | lonewolfinjax [ Thu Feb 04, 2010 12:15 pm ] |
sorry for being loud |
| Author: | Doc [ Thu Feb 04, 2010 1:22 pm ] |
Quote: ... close to the vacuum advance and fuel pump.
Yes, that is how it goes together.There is enough room, give it a try. DD |
