Slant Six Forum https://slantsix.org/forum/ |
Exhaust ?s https://slantsix.org/forum/viewtopic.php?t=38821 |
Page 1 of 3 |
Author: | Mister Twister [ Sat Jan 30, 2010 3:55 pm ] |
Post subject: | Exhaust ?s |
Just want some input. Good or bad what do yall think about the new exhaust we will run in the TwIsTeR thanks Don |
Author: | carlherrnstein [ Sat Jan 30, 2010 4:10 pm ] |
Post subject: | |
That looks nifty, but how much heat will the starter get? |
Author: | Mister Twister [ Sat Jan 30, 2010 4:22 pm ] |
Post subject: | |
yes we agree it is tight a header wrap would help but we have a mini starter it should be alot better. Just showing it would work. |
Author: | Joshie225 [ Sat Jan 30, 2010 5:17 pm ] |
Post subject: | |
Where are the collectors? It looks like 3 pipes from 3 ports dump into one overly large pipe with no thought or concern as to properly collecting or merging the primary pipes. It's better than sucking on exhaust fumes, but it also looks like a waste of time and effort. You'd do just as well to hack the center out of a stock manifold and weld on two pipes. |
Author: | ceej [ Sat Jan 30, 2010 5:24 pm ] |
Post subject: | |
I did header wrap and a starter blanket with mine. The amount of heat that gets liberated from this size headpipe is an issue otherwise. This is for a twin screw build, or are you going to install a single turbo back further? CJ |
Author: | Mister Twister [ Sat Jan 30, 2010 5:31 pm ] |
Post subject: | |
I should have asked if you think its better then the set we run now? |
Author: | Aggressive Ted [ Sat Jan 30, 2010 5:51 pm ] |
Post subject: | |
What diameter is the large pipe? Is the large pipe a shield with smaller pipes in it to form a collector? If so, what are the length of the primary pipes? |
Author: | HardCharger [ Sat Jan 30, 2010 6:32 pm ] |
Post subject: | |
Quote: What diameter is the large pipe?
Looks to me like exhaust scavenging is dead but the metal work is something to be proud of.Is the large pipe a shield with smaller pipes in it to form a collector? If so, what are the length of the primary pipes? Is this for a twin turbo build? |
Author: | Mister Twister [ Sat Jan 30, 2010 6:46 pm ] |
Post subject: | |
10-4 Ceej cant have enough protection. Ted the large pipe is 3" not sure we underdtand the rest of the question. Outside primary 8" from head to 3" pipe. Center primary 4" to 3" pipe. |
Author: | GTS225 [ Sat Jan 30, 2010 7:11 pm ] |
Post subject: | |
Yep...it does look like that starter might get a touch warm. I also suggest some insulation to protect it. Sidebar:....are you going to run that intake? If so, I suggest you give it a good coat of epoxy paint, if you haven't already. Roger |
Author: | Mister Twister [ Sat Jan 30, 2010 7:13 pm ] |
Post subject: | |
Shoot HardCharger its hard just to finish the list for my single turbo build. We have pondered the idea of twins mounted in the rear though. Thanks Don |
Author: | Mister Twister [ Sat Jan 30, 2010 7:24 pm ] |
Post subject: | |
Quote: Yep...it does look like that starter might get a touch warm. I also suggest some insulation to protect it.
Sidebar:....are you going to run that intake? If so, I suggest you give it a good coat of epoxy paint, if you haven't already. Roger Roger I think your being real nice with that one. The intake is just easy for me to get on and off. It will be used on the motor pic posted a little back in thread with the offy intake. |
Author: | Mister Twister [ Sun Jan 31, 2010 4:57 am ] |
Post subject: | |
Do yall think they will be better than the other ones I use? We can install all nuts by hand with these and adjust over-all length of collector real easy. These just happen to be the same bends and length for both front and rear. IE The same flow Don |
Author: | ceej [ Sun Jan 31, 2010 7:08 am ] |
Post subject: | |
The 3" pipes are too big. Gas velocity will drop off very quickly, and those big tubes are going to dump heat like crazy. Not sure where your mounting the turbo from here. It looks like it's going to be too far back to drive the hot side effectively due to the above. Go down to twin 2" pipes, and bring them together and into your turbo above the motor mount..Shorter is better. Unless I'm missing something in your build, you've too much head pipe volume there. CJ |
Author: | Wesola78 [ Sun Jan 31, 2010 7:32 am ] |
Post subject: | |
I don't have any technical advice to ad here, but HOLY ____! Those are some massive pipes. Looks like some top quality metal work, nice! I would like to hear it run. |
Page 1 of 3 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
