| Start the engine on a stand? https://slantsix.org/forum/viewtopic.php?t=38856 |
| Author: | sixertrk [ Mon Feb 01, 2010 5:49 pm ] |
| Post subject: | Start the engine on a stand? |
I'm rebuilding my engine and would like to start it on an engine stand first but I'm not sure how to wire it up. I assume batt wire thru ballast resistor to + coil. The starter I'll cable thru relay and use a starter push button to cross the relay. How do I wire the 4-terminal ECU and the 2-wire electronic distributor. Thanks in advance for any help!! |
| Author: | Greg Ondayko [ Mon Feb 01, 2010 7:38 pm ] |
Sorry I cant give you a better answer to your question, But this is more of an electrical forum question than an engine forum question. Also If you get a factoy service manual of the engine bay wiring schematic That should help shed some light on your problem. Good Luck, Greg |
| Author: | Kevin Johnson [ Mon Feb 01, 2010 7:43 pm ] |
Make sure you are using an engine stand designed to have a motor run on it. If you do a google search there are stories of motors flipping over. |
| Author: | emsvitil [ Mon Feb 01, 2010 7:44 pm ] |
It's more than electrical........ There's exhaust and cooling to worry about. and flipping over. |
| Author: | madmax/6 [ Mon Feb 01, 2010 10:14 pm ] |
Best engine stand to start the engine is your car.I tried it once with what I thought was a sound modified engine stand,first blip of throttle it was on the ground.not pretty.Stuff it.Mark |
| Author: | sixertrk [ Tue Feb 02, 2010 6:55 pm ] |
Thanks for the input. I have used the engine stand start up method several times before. But that was before electronic ignitions. If I'm supposed to move this post to electrical I don't know how. |
| Author: | carlherrnstein [ Tue Feb 02, 2010 7:58 pm ] |
try looking in the articles section on this site i would give you a link ,but i dont know how |
| Author: | sixertrk [ Tue Feb 02, 2010 8:39 pm ] |
Good tip. After a few attempts learning how to search the site, found a wiring diagram for the ECU. Thanks again. Great resource site!! |
| Author: | 66aCUDA [ Wed Feb 03, 2010 9:03 pm ] |
How do you plan on starting it? You will need a trans (auto) or flywheel and bell housing. Then how will you attach the engine? I built a test stand for my use it will take any slant configuration. Frank |
