| The Valiant's smoking! https://slantsix.org/forum/viewtopic.php?t=3886 |
| Author: | Joel [ Thu Jul 11, 2002 7:48 am ] |
| Post subject: | The Valiant's smoking! |
I finally have my '69 Valiant running much better. Here's my problem. When I punch the throtle, I get some smoke through the exhaust. I rebuilt my carb and realized that it was completely black inside the throat. It's an aluminum body holley 1920. Laquer thinner wouldn't dissolve the black coating. I don't know if it's carbon or some kind of coating that they put on at the factory. I don't seem to be burning any oil. Is it a problem with the air/fuel mix?? The car misses a bit until it warms up for a minute. Joel jbrig@enter.net |
| Author: | Doctor Dodge (Doug Dutra) [ Thu Jul 11, 2002 4:40 pm ] |
| Post subject: | Re: The Valiant's smoking, that means it's running |
: I finally have my '69 Valiant running much : better. Here's my problem. When I punch the : throtle, I get some smoke through the : exhaust. I rebuilt my carb and realized that : it was completely black inside the throat. : It's an aluminum body holley 1920. Laquer : thinner wouldn't dissolve the black coating. : I don't know if it's carbon or some kind of : coating that they put on at the factory. I : don't seem to be burning any oil. Is it a : problem with the air/fuel mix?? The car : misses a bit until it warms up for a minute. : Joel Running is good . . . Don't worry about the black "soot" in the carb. that won't hurt anything. Make sure the PCV valve and passageway / hose is clear, also be sure to run thick oil during the hot weather months. (no 10w-30) Keep driving and tuning, Slants may not always run well but they will keep running with a little care. DD |
