T5 swaps revisited
https://slantsix.org/forum/viewtopic.php?t=38863
Author:  volaredon [ Tue Feb 02, 2010 9:12 am ]
Post subject:  T5 swaps revisited
Of those who have done the T5 swap; I was wondering if either anyone here had info laying around, or else knew of a site to find measurements of shifter location front to back on the case, of the different T5's, (Mustang, Camaro etc) as compared to an A/F body 833/833OD?
I'm trying to figure out if the T5's shifter is "in the ballpark" of the F body console shifter hole. and also if it would interfere with the top of the trans crossmember.
Yes I know that they never used a console on stick-equipped F bodies from the factory; but I am!
Author:  64'4$peed [ Tue Feb 02, 2010 3:24 pm ]
The shifter on the v8 mustang T5 79-9? will be about 3 inches towards the pass side and roughly an inch forward. from a 64 A833 I believe Mcleod makes a $$$ shifter that allows you to relocate the shifter wherever you want it
Author:  volaredon [ Tue Feb 02, 2010 8:53 pm ]
64-4$peed; thanks for the info.
