oil filter (1806) work on a 2000 plymouth v6??
https://slantsix.org/forum/viewtopic.php?t=38869
Author:  hydrive1953 [ Tue Feb 02, 2010 11:45 am ]
Post subject:  oil filter (1806) work on a 2000 plymouth v6??
I know this probably should not be on hear :oops: , but I need some info. My wifes car is a 2000 Plymouth Voyager, and has a v6. On starting up and with-in the first min of start-up the valves make nose and then when oil pressure comes up it is ok.
I want to know if that 1806 oil filter would work on her car?? Would it fit? Would it help?? I put one on the 1975 Dart and it's great!! Would never put any thing but that on the car now!!
Author:  64drtGt [ Tue Feb 02, 2010 12:08 pm ]
If you think its the oil filter just go to advance auto and get the mopar filter for it. They are " specially designed to prevent that" .
Author:  Aggressive Ted [ Tue Feb 02, 2010 12:08 pm ]
No, the filter points the wrong way. It works on the SL6 because the filter is upside down so the built in stand pipe holds the oil. Sounds like you need thinner oil in the V6. What weight are you using?
You could use that NAPA 1515 WIX equivalent.
Author:  SlantSixDan [ Tue Feb 02, 2010 12:10 pm ]
Last time I checked, Mopar-branded oil filters are of poor quality. The #1806 is not the correct filter for that engine. The "use OEM filters because they contain a special valve to prevent dry starts" thing is marketeering BS mostly pushed by Toyota. Any good(!) oil filter that is correct for an application requiring an anti-drainback valve will contain an anti-drainback valve.
Ted's question is a good one, what weight and type of oil are you using? And which V6 engine does this vehicle have?
Author:  64drtGt [ Tue Feb 02, 2010 6:25 pm ]
Every filter i use people say are poor quality I know im young but my family has also used them forerever and never had issues. I know its a personal choice but untill I have a engine issue caused directly by a fram or mopar filter i am going to continue to use them.
Author:  hydrive1953 [ Tue Feb 02, 2010 10:50 pm ]
I think that the motor is the 3.8, and on the oil I don't know for the last year she has brought this one in for all that stuff. I am going to start doing it from now on. Shop said that that noise is normal, but I think that it is not right. I am going to mobile 5-30 and I will try that 1515. need to get one more year out of the thing. Have 124 thou on it.
Author:  SlantSixDan [ Wed Feb 03, 2010 7:03 am ]
They know what causes that now.
