It is currently Sat Jun 20, 2026 5:13 am
 Post subject: Disc brake upgrades
PostPosted: Mon Feb 15, 2010 11:12 pm
OK don,t shoot me but we are investigating the following two conversions over here
Tested and it works very well - Toyota Landcruizer 75 series 4pot calipers - virtual bolt in on LBP cars but you have to fit a 15 inch wheel as the caliper is enormous
Testing: Jetta IV TDI 4 wheel discbrake setup for Small bolt patterns - will send pics assap
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Tue Feb 16, 2010 6:38 am
Nice info to know.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
 Post subject: Re: Disc brake upgrades
PostPosted: Tue Feb 16, 2010 7:24 am
Absolutely not. 5-on-100mm bolt circle is not the same as 5-on-4". It is close, but "close" is not acceptable. This is not a safe thing to do. The same goes for 5-on-114mm bolt circle on Toyota wheels, which is not the same (and not safely acceptable) as a 5-on-4½". It probably wouldn't be hard to find 5-on-114mm wheels with RWD offset, but finding 5-on-100mm wheels with RWD offset would probably be difficult.
PostPosted: Tue Feb 16, 2010 12:41 pm
wobble nuts?
Regards,
Fanie Gerber
PostPosted: Tue Feb 16, 2010 1:00 pm
To hold wheels on? Good one! :lol:
PostPosted: Tue Feb 16, 2010 3:03 pm
Dan, I don't know about the Toyota Land Cruiser, But my 86 Toyota PU has 5 on 4 1/2 bolt pattern.
PostPosted: Tue Feb 16, 2010 3:25 pm
Car Model: 1964 Valiant V200
RWD toyotas are 5 on 4.5 (at least the vintage ones) aka 5 on 114.3mm
PostPosted: Wed Feb 17, 2010 11:02 pm
theoretically sounds good as 114.3 does convert to 4.5 inches but is it 100% exact? Issues with wheel register size would need to be addressed of course. (seems I remember someone saying that the old 300 z wheels were 4.5 bolt patt. along time ago, {way back}). What were the wheel offsets for the various toyota's using this bolt pattern? What cars did they put them on? What diameter would the wheels be?
{I wonder why toyota would use a 4 1/2 bolt pattern}
1979 W150 Shortbox
225, NP435, 9 1/4, Dana 44
The Good Life.
PostPosted: Thu Feb 18, 2010 6:00 am
Yes, 114.3 mm is just the conversion to 4.5". Many import cars have this pattern to make it compatible with US makes. Most are switching or have switched to a metric round number now, but several are still being made.
PostPosted: Thu Feb 18, 2010 6:49 am
The only trucks I am sure of is the pick-ups and 4 runners from 78-88. They were all 5 on 4 1/2.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Feb 19, 2010 3:46 pm
I demand pictures! :D
72 dart acquired 12/08 /6,holley2b, mopar perf intake, mopar perf header, cam, built motor,904 finally re-installed, 8.75....still needs sorting out.
99 dakota 318 5 speed reg cab picked up 9/09; Trans finally fixed! woohoo!
 Post subject: toyota wheels
PostPosted: Fri Feb 19, 2010 6:07 pm
Now this is interesting. I will have to check this out at the salvage yard.
Actually, this could give some options to wheel choice in certain applications. Maybe brakes too.
1979 W150 Shortbox
The Good Life.
PostPosted: Fri Feb 19, 2010 8:15 pm
I'm pretty sure that the Doctor Diff rear disc brake kit uses Toyota rotors. Toyota out back and Mustang up front.
I use Mercedes rotors in one of my kits. They are close enough to work. The rotor centers on the hub register so the holes just have to clear, they don't need to be perfect. The rotor is held on by the wheel so it can't go anywhere once the whole assembly is together.
PostPosted: Fri Feb 19, 2010 10:56 pm
Indeed they do - I have his rear disc kit. They come stock 5 x 4.5"/114.3mm and he redrills to 5x4" for us SBP folk. When I asked for application he said 4th generation 89-92 Toyota Cressida. Pix here.
PostPosted: Sat Feb 20, 2010 8:21 am
Interesting, I had't seen the SBP version of that kit before. If you have high resolution pictures and are willing to let me use them in a book I'm writing let me know. I'm not really focused on SBP options but I'll include a picture in the book just to let people know the option exists. It is a nice illustration of the possibility.
