| carburator https://slantsix.org/forum/viewtopic.php?t=38898 |
| Author: | hello, operator [ Thu Feb 04, 2010 7:52 pm ] |
| Post subject: | carburator |
Building a sheet metal intake and tube headers for my slant six. i am wanting to convert it from the single barrel carb to a two barrel. What carb came on the original super six motors? is there a preferable two barrel carb other than the super six's? thanks |
| Author: | Fab64 [ Thu Feb 04, 2010 10:05 pm ] |
Check out page 44 in manual #1 (the first link) on this page: http://slantsix.org/forum/viewtopic.php?t=38601 Some people have used a BBD from a 318, but the true Super Six carb is supposed to work better on a slant. You should be able to find one on e-bay. Good luck. Roger |
| Author: | 66aCUDA [ Fri Feb 05, 2010 7:39 am ] |
The super six had a Carter BBD or a Holley 2280. Another good choice is the Holley 5200. Hope this helps, Frank |
| Author: | hello, operator [ Fri Feb 05, 2010 12:40 pm ] |
thanks to you both, this helps a lot. Hello, operator. |
