8 1/4 crush sleeve
https://slantsix.org/forum/viewtopic.php?t=38905
Author:  D-Ram 1596 [ Fri Feb 05, 2010 10:21 am ]
Post subject:  8 1/4 crush sleeve
I have an 86 D-Ram and ever since I have had it there has been a wicked clunk when you throw it into reverse. It has probably been talked about on here before, but is this a big part of the noise? My U-Joints are pretty good, my trans dosn't had any issues (I hope). If it is has anyone out there fixed it before, and is even worth the time?
Author:  bigtex [ Fri Feb 05, 2010 11:40 am ]
just something to check before you start looking at the rear end is leaf spring bushings, if they get some slop they will cause a clunk when going thru the gears
Author:  dakight [ Fri Feb 05, 2010 1:43 pm ]
I don't believe it would be the crush sleeve. I suppose excessive backlash could cause such a clunk but I would look elsewhere first. If it's excessive clearance somewhere in the rear axle then it won't be a cheap and easy fix.
Author:  hantayo13 [ Fri Feb 05, 2010 3:23 pm ]
replace u-joints they are cheap/easy.....check frontof spring where they wrap around bushings...mine had tops broken off ....so did every set i had ....i bought new main leafs and built my own spring stack, can now haul a ton easy
keep on roddin'
Author:  D-Ram 1596 [ Sat Feb 06, 2010 6:18 pm ]
Hmm, never would have though of looking at the leaf spring bushings, that is something I will have to look when I get back home. The U-joints are going to be replaced when I change out motors.
If the 8 1/4 ever does give me anymore problems I am most likely just going to find a replacement 9 1/4, I guess I will just live with the clunk for now.
Author:  theomahamoparguy [ Sat Feb 06, 2010 11:57 pm ]
Just for the heck of it, check to see if your pinion nut has loosened. This does happen sometimes.
